Where to dyno car in Singapore?
Racebred said:
no dyno in the world will be super accurate. at least you'll just be able to get a certain ballpark of how your car's doing.
desmond, have you dynoed your car already?
yah not accurate but at least should be believable right? Ball park is ball park, but some ball parks are bigger than others you know what I mean...
All I am saying is that need to be consistent lor... if dyno on one type of dyno then stay on that one type.
Btw, my M3 cannot dyno. there is a wheel sensor in the front wheel and if the front wheels is not spinning at the same speed then the rev will cut at 6500 rpm. So no point dynoing the car...
go to e46f and search the sequence on how to disable the m3 background dsc. should be able to dyno if you switch it off.
will go look lah.. but I think it will be too much trouble.. don't want to hand itchy later got more problem to clear... btw, my car already run in liao... hehehe
Dyno-ed my car today. The electrical systems went berzerk for 5 minutes after that.
Scanner not working so can't most graph yet.
I did call up Doctor's 325 for a comparison. ;)
Doc's power curve is parallel but slightly above mine. Peak power remains the same. I have higher peak torque and more torque at high end.
Interesting... must have something to do with your intake and exhaust manifold design...
Tanzy,
Most importantly whats the shape of the power and torque curves?
Power curve should be as linear as possible and torque curve should be as straight (horizontal) as possible so you can get as near to peak torque at any RPM. (from my understanding lah...)
SMYUEN said:
Tanzy,
Hi Doc, a street engine is pleasant to drive the earlier the torque peaks. The ease of driving (power width) comes at the cost of pure power potential (hp/litre) of the engine.
The higher tuned an engine is, and/or the more flexible the gearing (more gears, or wide range CVT), the higher up the RPM range the torque peak is going to be. Some high tune street engines.. M3 torque peaking at about 5000rpm, Stradale around 5000rpm, S2000 around 6000rpm. In these cases it isn't so much a having-peak-torque-everywhere situation, but more one of having more and more torque the higher rev goes (hence power). Not less now, but a lot more later. The larger the displacement of an engine, the more comfortably you can get away with moving peak torque up the rpm range since the dispalcement will still inherently provide sufficient torque down low even as you tune away from it. With big engines on street tires you end up nuking the tires anyway which does nothing for acceleration, so might as move it up to provide more useful power later.
It is possible to go to either extreme - one being very early peak torque, severely compromised overall power, low stress, low fun engine - the other being very late peak torque, very high power but in too narrow a range, high stress, high fun (challenging to drive) engine that takes ten tenths to drive properly.
This all is subjective, but personally I consider sporty street engines to have the peak torque at least after the first 50% of the rev range - preferably after the first 55% of the rev range. Pure race engines even later...
Question :screwedu:
How come the torque curve start from 200+Nm ? Some start from below and some start from top... :screwedup:
calvin said:
Question :screwedu:
Notice the x aixis of the graph only starts from 2000 rpm...
Err.. question, this graph is after correction for drivetrain loss or not?
you can disregard anything below 3000rpm because the measurements are not refined enough to measure it correctly. all the dynos i have seen by ST power will have tremendous torque below 3000rpm. thats when the fella starts flooring your accel.
tanzy's figures are crank figures. losses are calculated when the car is decelerating at zero throttle position.
ambient temp corrections, usually 2-3% are also factored in.
you can go back and request for your true bhp on the wheels. they should be able to print that out for you.
