where to buy Bilstein & Eibach Pro kit
donaldho
Hi, anyone know where to buy Bilstein/Koni Shock & Eibach Pro Kit? Any local dealer that I can get at package price for my E60? Thanks in advance!
Re: where to buy Bilstein & Eibach Pro kit
alright donald! lower your ride.. slam it! then mod it to look like your sig pic!
Lowering springs always have too low in the front & not low enuf in the rear for E60.
Beware.
Only proper coilovers can adjust the ride height nicely.
'The Great White'
I believe Benzline would have it. Give them a ring. :)
eng soon do sells them but i dont know if they have stock
Thks guys for all your responds, anyway I have checked and most of them have no stock except for Eng Soon. But, I wonder is this a good combination? Or should I go for new stock shock absorber and Pro Kit, afterall Pro Kit springs is design for stock, right? Btw my car 3 yr o liao so need to change, budget within $1.5k.
your budget should fit nicely on a set of Koni FSD absorber with Eibach pro kit spring.
Sound COOL! Will go for that. Thks bro!
Donald, If I were you having the 525i, I will go for coilovers setup. Although this set up may cost you about 3k+ but the benefits you gain even more. Really worth the investment.
Er... way my budget leh. So many things to buy with so little money...still got BBK, oil cooler, high pressure water pump, etc, etc.
if you are going stock springs, then normal stock replacements... upgraded shocks will sit your car higher and will look funny... lowering springs on stock (OEM) replacements might wear out your shocks faster...
you may want to upgrade to harder shocks and acquire second hand lowering springs to save you some money for othe mods...
