When to replace wheel bearings?
gks
Hi all,
Just wanna check if there is any recommended mileage to change wheel bearings? When driving without radio on, there is 'whorring' sound from outside the car. Suspect it's the tyre but dun think so cos it's still quite new (advan sport). So now suspect it's the wheel bearing. Car mileage is now about 130k. Could this be the cause of the problem?
KS
Re: When to replace wheel bearings?
could be alignment, go get it check and if new tires? if alignments not done? will cause uneven wear also.....
Hi bonsoir,
Thanks for the info. Had already done wheel alignment. Problem still there. Dunno if the tyres are more noisy? Or there is something else to this problem.
KS
