When should change the control arm bushings?
BMWSILVER
When is the time to change the control arm bushings?
It is true that changing to aftermarket bushings will improve the car handling but may have vibration and noisy?
Should I install OEM or Heavy Duty or PowerFlex bushings?
Anyone has installed above bushings please comments :)
Re: When should change the control arm bushings?
changed mine once at 30 000km and once at 70 000km..used back OEM stuff...
Hi ! Terry.
Thanks for your reply :)
Anyone installed Heavy Duty or PowerFlex bushings can share their experience?
I think Nolathene is the best option, OEM ones are crap
In my humble opinion, i dont think Nolathene bushes gives you a harder ride, but it does stiffen up the handling. But you must change EVERY bush in the front end. Swaybar, control arms etc
:) Hi, i changed mine when car abt 3 yrs old, they shouldn't be noisy and have vibrations. Infact it should be the same as stock but diff is that it's a harder material and makes the car feel 'tight' when driving as there is no play between the connections. Im using powerflex and considering now to change all the bushings in e other areas to powerflex as well incldg subframe etc. Gonna be a big job tho !!
Verdict - buy them ! coz yr stock bushing anyway will wear out eventually in abt 3 yrs depending.
For u, just u only...stay with stock
For Rastaman, he needs heavy duty one.
I m using Ground Control...squeaky at first but went away afte a while and it's so tight.
Hi ! Rastaman.
Hi ! Jack.
Thanks !
the rubber shit they put between the metal so that your ass dont feel so bad and suspension don't clunk every time the metal move.
they r not cheap them bushings...i think mine needs to change..can hear a bit of clunkingn creaking....
I am sure they are reasonably cheap in Aus, I will check next week
Bushings are cheap but for brand cars like Maser aint..hur hur..
Any noise created after installing the Heavy Duty bushings?
I don't mind firmer but I hate noise :(
I had problem with my Anti-Roll Bar and had it greased many time but still have noise :(
you want performance, then live with noise
you want no noise and no performance, buy OEM
bro....heavy duty bushings for yr control arm like powerflex....good shit....go for it...!
Will do it during the next servicing :)
When if your new car coming?
Can Taxi Ride or Not?
