Wheel alignment for Porsche
precurser
Hi chaps,
My GT3 just hit the 10,000km mark. Taking of bringing it for wheel alignment.. is there a recommend place that I should go to? Experience with Porsches is a must.
Thanks!
Re: Wheel alignment for Porsche
try leong seng tyres at ubi ave 1
You may also try South East Asia Co.
Blk 7 Sin Ming Ind Est Sec C #01-92
6453 6228
cheers...
Kian Tiong Auto Centre
AngloINFO: Kian Teong Auto Centre
Yes experience with all types of Porsches, including 997 Mark 2 in database of alignment. If you want aggressive alignment you have to be the one to tell him which pin to remove for the extra 0.5 degrees.
Des,
I go to FlatSix Engineering
They use a very old school traditional/manual method. Happy with the results. Not cheap tho and it takes half day...
Another good one is Espace, arguably best for Porsche but damn expensive too.
My other cars, i go to Kian Tiong
TripleM;438412 said:
Des,
Yes I am thinking of sending my car to Espace to do the wheel alignment. They use a very traditional method. Using strings or something. Very expensive but Andy has got very good experience with many cars, and that same alignment method is what he does for even the Cup Cars.
Des,
Ok thanks. I'll give Andy Tatlow a try. Is 10,000km the right mileage to check on alignment? What's the est cost for the job? Gonna be first time there, so don't want to get carrot.
Satin man
Yep, F6 uses those strings, machiam dental floss for elephants.....
Precurser
U got PM
strings are used in everything from formula ford and spec miata all the way up to indycar and le mans prototypes - fine fishing line most often. other systems that save space in the garage and transport space and weight (favored by gp2 and f1 most commonly) allow alignment while the car is up on stands with the wheels not mounted, but alignment plates bolted onto the hub.
