wheel aligment
mono
Hi guys! Do need help here.i hv just changed my ride to 19".And is it true that once the rims and tyres are changed,wheel aligment is a must to do? and if so,who do you guys recommed?
Re: wheel aligment
.........no bros out there that can help me on this issue?
Re: wheel aligment
Try Kian Teong @ Sin Ming. Contact under Resources or you can look for Kenny Alignment at AMK Autopoint.
Re: wheel aligment
You don't have to do cause you don't move the suspension in any way, so your toe/camber settings should be the same.
Re: wheel aligment
Only balancing need to do each time u change ur rim and tyre..
Re: wheel aligment
Really appreciate those advises given by you guys......thks again !
