What tyres profile to use on 19" Staggered Rims
nnb239
Hi guys, can advise What tyres profile to use on 19" Staggered Rims
Model E90 320i LCI
Thanks in advance.
Re: What tyres profile to use on 19" Staggered Rims
Really depends on width of tyres. Generally 30-35 should be good
I'm looking at. Correct me if its wrong. Thx
F 235/35/19
R 265/30/19
F 235/35/19
R 265/30/19
Also depends on tyre brand ;) PSS comes in 265/35/19 if not wrong
Nice ride Ryan, Thx for the lovely pic.
How are the tyres when cruising.
tryes are fine. consider the fact that they are korean tyres. roadstone N3000.
i did consider PSS but thinking that they are staggered and can't do tyre rotation i decided on roadstone instead.
Its hard to beat the grip and performance of PSS tyres. They will last longer than your average tyres as well.
Same for me too, F 235/35/19, R 265/30/19. How about the tyres pressure? Care to share? I'm on front psi 280, rear 300.
I went with F 235/35/19 (240) and R 265/30/19 (270)
I went with F 235/35/19 (psi 230) R 265/30/19 (psi 240)
If the tyre pressures for all e92s are the same, you guys are under inflating your tyres. On 19 inch rims, you guys should be on 290 front and 340 rear.
With my setup and Recommended from my mechanic bro.
Guys, look at the recommended tyre pressure on sticker inside your driver's door panel. Has recommendation for 18", 19", 2 or 4 passagers, etc. That should give you a good guidance +/- a bit depending whether your tyres fully warmed up or still cool
hey bro. wonder where this recommended specs are from. On my current profile (260 front 280 rear) I already find it pretty harsh. running PSS and when i vary the pressure between 230 to 280 the comfort of the ride gets compromised a fair bit.
Hey, im running a 19 inch staggered rim with 225/35 front and 255/30 rear. The label by the driver's door says to inflate to 290 front and 340 rear. Are you driving a 1m? Those tyre specs are huge.
Also right now, im running conti contactsports, which are WAY softer and quieter than PSS. So perhaps for me it might be ok but for pss users no. However, its the pressure that the BMW recommends. Anyone who wants to weigh in on this please do.
245/35 front 275/30 rear, was told by 2 diff tyre shops to pump 250 front and 260 rear. 19" pss.
I am using CSC5P on my F32. (I really hate this tires as they wear out super quickly)
235/35 front and 365/30 rear.
Was recommended tire pressure of 240 front and 260 back.
Hi there. I'm planning to replace the current tyres and am looking at the same setup as yours. Mind letting me know how much you paid for your pss?
m8winac
