BMW Service Symbols - howtopdf.com - Resources for Free PDF Tutorial
Diagnosis test.
- Horn, headlight flasher and hazard warning lights.
- Instrument and indication field lighting, check heater blower.
- Windscreen wash/wipe system.
- Body: checked for corrosion.
- Tyres: tread depths, tread pattern and external condition, check inflation pressures and correct if necessary (spare wheel checked also).
- Battery: display checked, and if necessary, replaced. – If your car is a few years old it is worth getting your battery checked prior to the onset of cold and damp weather, as these conditions can contribute to deterioration in the battery.
- Steering fluid reservoir: fluid level checked.
- Coolant level and refill if necessary: if there’s too little water and anti-freeze in the cooling system, then the engine can overheat and cause potentially serious damage.
- Windscreen washer system: check fluid level, top up if necessary.
- Brake lines and connections: checked for leaks, damage, and correct position.
- Under-body including all visible parts: checked for damage, leaks and corrosion.
- Steering components: checked for clearance, leaks, damage and wear.
- Check for roadworthiness
Brakes
Steering
Shock absorbers; and
Clutch / automatic transmission
ADDITIONALLY: A Standard Scope inspection is carried out on your BMW when it is brought in for a service. This inspection includes:
* Check of control messages.
* Check of telltale and warning lights flagged in the LCD display.
