Water leaking into car. E46
danielO
Need some help here.
The past few months i have been dreading the rain. When it rain, water finds its way into the car, soaking the interior carpet. Managed to track it recently and it is dripping in from the outside window sill down between the interior door trim and out the bottom of the door trim onto the car. The workshop blames my ICE as the the metal plate in the door was cut to fit my aftermarket splits. But it seems its only my car that's having this problem. The ICE was installed 4 years ago, the leak about 3 months ago.
Anyone else has and solved this problem?
Re: Water leaking into car. E46
Check the insulation form, should firmly attached to the door - e46fanatics has quite a lot of discussions.
check the rubber seal at the air-con if u only get it on heavy rain.
but i driving the E36, happen before.
