My ride is E46 M54.
Yesterday, 2 minutes after driving off from cold the EML, DSC and amber Handbrake warning lights came on. Engine lost power and had to pull over. Switched off engine and started and no more problem.
Today, same thing happened again 3 times. First time from cold and the other 2x when engine was warm.
Went to PML to check. Quick diagnostics showed DSC and DME (DEM?) may be the problem, with the idle valve as a probable cause. The mechanic asked if I was using KNN filter and said the oil from the KNN may be causing the problem and advised to send ride in for full check. Also recommended to replace stock air filter as this may help eliminate unlikely causes and narrow down the troubleshooting process.
Do any of the bros here still have their old stock E46 air filter sitting around that I can borrow? A new air filter does not cost much from lobang from another post. However, I do not want to raise suspicions going in with a new air filter.
I kept my old stock air filter of old ride for 5 years without having to use it again. Now with this ride, 5 months after throwing it away I need it! Such is life!!!
Appreciate anybody who can help. Thanks.
