Wanna Sell: 3.0L Fuel Injectors
Re: Wanna Sell: 3.0L Fuel Injectors
do they fit the e60 532i? if do does it make a difference?
Fuel injector acts as the fuel-dispensing nozzle that injects liquid fuel directly into engine's air stream. From what I gather, it depends on your current fuel injection duty cycle (AFR readings?) and if your current ones are oredi maxed out, you will need larger injectors to input in more fuel. Sorry not gd with such technical details, experts pls help! Not too sure if it fits 523, I can check with Ah Wee.
rex7_vtec;266641 said:
I seriously doubt it will fit the 523 seeing that you are not running a M54 engine.
Perhaps with some modifications it may but yet again without a programmable ECU you could be just wasting more fuel
ok thanks a lot
Thank u barry!
I am running these on a E46 M54 engine with Orbit II tuning. These are spares sitting in my storeroom.... anyone??
These injectors do not fit the current N52 valvetronic engines as they use direct high pressure direct injection into the combustion chamber. (like diesel engines).
For those brudders that are running "snails and large alternators" on their 2.5L or 2.2L M54 engines, these injectors are a must to help supply fuel especially when the pressures go up.
Bump Bump
