volker iridium reviews after 1500km 6wks
audibum
Bros, wanted to share with u what hap to me and my ride...
I went to kranji loop with a e46 valvie at UM2 to have my spark plugs replaced from my denso ik22s to the much talked about volkers, i think i had the 7zx-8...or something like that...
initial drive was idling markedly smoother and throttle response livelier.
but after 4 weeks, idle started to be jerky, normal idle aircon on is about 800rpm but at traffic lights sometimes shoots down to 500-600 momentarily and maintains 800, possibility of misfiring apparent.
drove for another 2 weeks with intermittent problems on my a4 1.8t with numerous occurrences of the aforesaid problems.
went do to my usual workshop on saturday and had my original IK22 densos fitted back, no more problems!
went to google a lil and found this article in a local forum....
quoted from Sliderzhil
"[Corsasg] Re: Denso Ir plug IK20 on Optra [In reply to] Cannot Post
Hey bros,
something to share with you all out there about volker iridium plugs. I got a set from the authorised distributor all the way in Kranji Loop for my ride 2 months ago. When I bought them, the first impression I got was that these plugs were finished poorly as the ground electrodes on all 4 didn't look uniform. Anyway, I thought I shouldn't let that bother me. So, I installed them (carefully torqued with my torque wrench) and drove around for about 2000km. Recently, my idling seemed quite erratic and so today, I decided to take them out for an inspection to see how they were doing.
Among other things, I used my multimeter to measure the resistance of the plugs, from tip to nut. All 4 plugs registered way LESS than 5k ohm! These plugs supposedly have got a 5k ohm resistor in them. One gave a reading of 2k ohm while the other 3 measured 2.2~2.6k ohm. Obviously the resistors in the volker plugs failed.
My used set of denso iridium IK20s all measured 5.1~5.5k ohm. Says a lot about the quality of volker iridium plugs. So much about being able to last 160,000km!
It's back to denso iridium for me..... this time VK20. And lo and behold, the engine became smoother after that.
Sourced from toyotaClubSG.com thread
http://forum.toyotaclubsg.com/viewtopic.php?t=10251&postdays=0&postorder=asc&start=0 "
I WANT MY MONEY BACK....SO MUCH FOR THE SUPER LONG TERM GUARANTEES...
anyone else out there with similar experiences?
Re: volker iridium reviews after 1500km 6wks
So far so good in both my cars and others BMWs in the general. Havent heard any -ve reviews bout the plugs to date. Even one Mini n Evo guys are happy bout it.
I do not have any problem on Volkers after so many weeks. Perhaps all we need is for the Volker Guru to clear the air...... Yendor?
I thot the second review in quote from Audibum about the experience of another driver was explained by UM2/Yendor as the older generation of Volker plugs? Anyway, had mine for 2 mths liao. So far so good.
think the previous post was on Honda civic car if i aint mistaken
Wah liao, guys, dun say me guru leh....
Audibum, I definitely remember your installation. You had a little brush with the law that day right?
OK for your problem, I cannot ascertain what is the issue just yet until i see the plugs. I have come across another problem in another VW engine. The plugs were damaged due to detonation within the combustion chamber. The damage was so bad that it caused the ceramic insulator around the tip to slide around. There are other stock VAG cars that used the plugs without any problems. Incidently that car ran 1.4+bar of boost.
Please bring your plugs down to UM2 and CP will either give you a refund or give you a replacement. I would suggest that you take the refund or upgrade to Spec II plugs to handle the detonation problem.
Oh yes, the clip that you posted came from the SHC forum, and the issue was addressed in the spark plug thread. CP is trying to restore customer confidence in the brand. All of the forumers have thus far all enjoyed the plugs. Just pop round to settle your plugs.
Rodney
Tks for the reply, will drop by when i have the time...hopefully this trip there won't cost another 12 pts, hhaha...
cheers!
just installed a set of 6 volker plugs... something like 8zx. so far only use for 3 days. any other using this plug?
40k km, no probs...
What caused the detonotation, Yendor?
There are several causes of detonation.
Eg, running too lean. It will cause detonation. A spark plug that is too hot (wrong heat range used) can also cause detonation. A fuel with too low octance value will also cause detonation.
Centurion, sent you a PM liao..
sky88ren
