Re: vertical line on side mirror
gadgets said:
erh, shouldnt it be to put switch in the "right"? asked this befor too and that was the answer i've got...
The passenger mirror tilt is dependant on the model also.
For E46
1) when your switch is on the left (passenger), the passenger side will tilt down according to your preset.
2) when your switch is on the right (driver), the driver side mirror will tilt down according to your preset.
*preset is when you put into reverse and you manually adjust the tilt to your desired angle, even upwards.
For E90
1) when your switch is on the left (passenger), mirror tilting is DISABLED
2) when your switch is on the right, passenger left mirror tilts down.
And I rechecked, the vertical line, the mirror is convex - thus wide-angled. Please check again.
kekeke
