Tyre Pressure E92 335
Jiunn Siong
I'm running on Breyton Race GTS 20" fronts 8.5" 245/30/20 and rears 10" 275/30/20 and using tyre pressure 250 front and 270 rear.
Keen to hear what you all are pumping at and your suggestions. Did a search but didn't see any specific threads on this.
Re: Tyre Pressure E92 335
bro, am on 240 all round. best combi in my opinion after trying many diff pressures countless times. not too hard not too soft. do try.
Am running on 19" breytons like u. u shld know.
if ur tolerence for bumps is higher go 250 all around.
If I have lower profile tyres, does it mean I should increase the pressure to compensate? Already on 250 front and 270 rear and wondering if I should be going any higher on the pressure.
most would say yes. reason being the profile is low and u risk slamming ur rims against pot holes. i have been on 240 pressure for more than a month now no issues. can feel the thud when i go over bumps and yet not spongy.
whats ur concern? so maybe from there can adress if shld up or down the pressure.
No specific concern...just want to know what everyone else is pumping their pressure at.
ur current setup is what most would reccommend.
OT: u driving X5 more often these days? seen u a couple of times but no longer in the 335
35/240 front and 36/250 rear for me. full load 38/260 rear. i'm on 19" staggered 235/35 and 265/30
on track 32 front and 33 rear before tire warm up.
18" stock RFT: front pump 250, rear 270...after that, switched to 19" F1 asym: front pump 230, rear 250
leebmer, do u find the font a little soft? am pumping 240 now on my fronts.
so far ok, maybe didnt corner fast enough...haha...
whahaha. i usually gauge when i go over humps. it shld give a resounding thud. but when it get soft like pillow feel, then i know lao hong liao.
May i chk wat's the recommended pressure for stock 16"? And wat most of u normally pump if different from recommended.
Txs in adv.
210 kpa shld be enough all around
Yeah...wife keeps stealing my E92 for her afternoon runs with the kids! Sigh...
beembeem;504055 said:
Bro Slater,
Txs for the info.
Beem
have a go at it and see how it feels. increase and decrease by 5 kpa if u find it too soft or too hard
Bro Slater
I've been using ard 240 on my previous Japan ride on 16". For RFT pressure need to be lower than normal tires?
beembeem;504074 said:
Bro Slater
240 for 16"??!?!?! too high liao la! RFT's side wall very hard liao. slightly lower pressure is ok wan. i use to have 17". pump around 210 kpa as reccommended to u. ride is compliant and nice. not harsh over bumps especially since RFT's r quite hard.
dun worry, wun tua u wan. if u really find too soft up it to 220. but dun pump too hard, else u will be sending into PML for rattling noises. preserve ur interior man
Haha, no la, 240 for normal tires. RFT's r something new to me, so not sure wat r the norm specs for them. Will try ur suggestion n feel feel.
Haha, if our rides' interior r so easily rattled by high pressurisd tires, then I really ought to consider if still getting this brand for nex ride.
