tyre fitment question
abcd
Hi
Anyone can advise if fitting 205/50R17 Bridgestone Potenza S001 on 17 x 7.5jj rim will stretch the tyres too much? profile too thin?
TIA
Re: tyre fitment question
abcd;772983 said:
Hi
TIA
or which variant???
I don't think so because F20 116i comes with a 7jx17 rim with 205/50 R17 tires...
Therefore, with a slight difference of 0.5j, should not be too tough on the tires...
abcd;773019 said:
e36 sedan 6 cyl
Oh i see
ok, the profile will be: 215 / 45 / 17
abcd;773026 said:
Thks man, 205/50/17 too thin profile?
can also.....................what profile are you on now???
now on 16" - iirc, 205/50/16, so cant compare ......
go for 215 / 45 / 17.........
abcd;773052 said:
yup, better fitment la
thks bro
no problem....
remember to turn up this 25 March 2012, Kallang Leisure cp F: 4.30pm
will get C3PO to inspect your off-set personally.....
* you lot is number E36
ac323;773054 said:
no problem....
will try to turn up if time permits.
u guys have fun
for e36 i will recommmend 215/45/17.
dont see the reason why should you go for lot less common size 205/50/17
Anyone can advice the air pressure for the 19inch continental tyre.
Currently driving E90.
Tyre size:
Front : 235/35R19
Back : 265/30R19
