Tyre advice
check13
Need to replace my can't really make it 19" CSC 5P very soon. Wat Michelin models would be around the same range in terms of price, noise n grip? Or Bridgestone GR90 will do as well?
Re: Tyre advice
can share ur experience wat u mean cant really make it on ur current 19" CSC 5p??
Re: Tyre advice
PSS.........
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
Re: Tyre advice
I find the grip not good at all especially on wet roads. I'm not the cheong type btw.
Re: Tyre advice
Bro, I was on PS3 previously so wondering if it's still ard or is it replaced by PSS?
Re: Tyre advice
GR90 wet grip is even worse than csc 5p cos its an all out comfort tire. The quietest riding tire I ever tried, even lower noise than yokohama db decibal.
You have to tell us your expectation from the tire before we can suggest any to you.
Re: Tyre advice
within similar price bracket and performance
from low to high price
1. Goodyear ASY 2
2. CSC 5P
3. Michelin PSS (most expensive)
Re: Tyre advice
BTW, site sponsors have some good deals on PSS.
Anyone know why such a big range in PSS tyre prices? Same size tyres can have a wide range in price depending where you ask. I've check year of manufacturing and all are 2013 but prices varies a lot :thinking:
Re: Tyre advice
Parallel vs AD tyre ... double check
in fact i don't mind PI tyre as long as origin is the same
Re: Tyre advice
Yes, I have the same thoughts. Just amaze at the price differences. About to change tires so been checking around for prices, will do more digging before buying.
Re: Tyre advice
Hiadee, I almost choke on my hoonkeee when I read that you have found 19" CSP 5P to be cant-make-it.
Well for a start, you should also look at some reviews on tirerack and BTW if I am not wrong, CSC 5P is used on some perf marques like AM and some AMGs (in the USA at least) so how bad can it be? I used 19" CSP 5P prior to my current set of Michelin PSS and contrary to what some say, I actually find CSC 5P slightly better. The downside with 5P is the tyre has a lower wear rate so wears faster, but that's why it is a good perf tyre if you forget about the value-for-money thing for a while. May I also ask how far have you pushed the CSc 5p? you might wanna try taking it up north to Kl or further n pushed it above 200kmh and u can see how steady your car is. dry n wet on hilly winding roads n NSH. What u should not do on CSC 5p is pump the tyre pressure too high. Around 220-225psi will do(cold).
So after all this why do I try PSS now? bcos I got a good deal and CSC 5p was out of stock at that time and dealers sell it close to PSS price(another reason why I don't agree CSC 5P is CMI tyre). PSS has a higher wear rate but I do find the compound of PSS a little harder(but of cos, 300 vs 240 WR?). Both CSC 5p and M PSs are overall good perf tyres.
Oh u are considering GR90 also? It happens that I also used before, for 3 weeks and then I traded off for CSC 5P. My 2 chao ah beng cents is - screw the GR90. First thing u notice is the width problem. 235 isn't really 235. When mount on my 8.5 front rim, 235/35/19 looks like 215/25/19. Farking Bridgestone must be using the wrong ruler to measure when they manufacture the tyre. Ok now the perf or the lack of it. u floor the throttle on NSH, say from 100kmh. u get tyre spin, tail swing, SMLC swing...no confidence at all on same tyre pressure as CSC and Michelin. I tried it bcos they say it is 'quiet n comfortable n grippy'. well grippy it is not.
So my chao ah beng advice. if u are hardcore driver n drives yr machine hard, take CSC 5p or M PSS. If u don't mind faster wearing off, CSC 5P. if you mind, take PSS. Screw GR90.
Re: Tyre advice
Oh u are considering GR90 also? It happens that I also used before, for 3 weeks and then I traded off for CSC 5P. My 2 chao ah beng cents is - screw the GR90. First thing u notice is the width problem. 235 isn't really 235. When mount on my 8.5 front rim, 235/30/19 looks like 215/25/19. Farking Bridgestone must be using the wrong ruler to measure when they manufacture the tyre. Ok now the perf or the lack of it. u floor the throttle on NSH, say from 100kmh. u get tyre spin, tail swing, SMLC swing...no confidence at all on same tyre pressure as CSC and Michelin. I tried it bcos they say it is 'quiet n comfortable n grippy'. well grippy it is not.
Good post. Time to change rear tyres and after some research, it looks like PSS still the way to go for wear rate & performance. Now to find a good lobang :)
Re: Tyre advice
ABD, I not hard core driver nor do I drive hard core car la. But I still find csc5p cmi compared to Michelin ps watever number I used before as I can't rem liao. Best part in after hitting the kerb recently, I got a "chip" off on the side of the csc5p side wall. Never happened before in my 15 yrs of kerb hitting experience.
Think I really can't stand the grip on wet roads.
Re: Tyre advice
Yup. I think CSC5p is lighter and has a lower rolling resistance........it is sensitive to certain type of road surface (light gray) for noise. Quiet on all others.
The wet performance I think is better than PSS.
JuzMe;1037810 said:
Here are some specs on PSS.
