Re: Top Gear shows why a BMW M3 is more economical then a Prius
Clarkson and Top Gear have their own agenda, which is to keep the sports car market alive because that's their business. To advise people with lies is pitiful.
The test is as flawed and pointless as their car vs jet/sled comparisons, etc. and in the end you have Clarkson the idiot preaching that it is not the car but the driving style. This is much more false than true especially when you consider the kind of roads and traffic that cars are increasingly run on. The truth is the weight of your car, and its engine size and technology affect things much more so than how you drive on roads that you drive on 98% of the time.
The M3 only beat the Prius because they were driving the Prius in a way so far out of its design envelope. If you take a look at how the Prius attains its effciency and where it is most efficient, you will understand why lapping for best time destroys so much of its advantage (short max effort braking events not allowing recovery, still turning mostly to heat at rotors, and direct electric drive being only maginally more efficient than engine alone) . It is also a myth that small gasoline engines are efficient. They are efficient at low load city type driving because of low component mass and friction, low total surface area for heat loss, but at high loads (as in track applicaton), they have poorer surface area to volume ratios, and to make sufficient power require high engine speeds (high friction). Larger cylinder displacement (larger engines in general) fair much better at higher loads with less of a requirement to rev high (friction increasing with square of RPM), and better surface to volume ratios.
Also, how the test was run, may not be what is implied on screen. The verbal description of the test is accurate, but there is much else that can happen within the broad description that allows the result to be moved whichever way they want. One way to do this is have the M3 lap at the same laptime, but with a much more constant speed, which is entirely possible by higher lateral acceleration capability (better tires, bigger patch, better mass distribution, better damping, better kinematics), taking it much easier on the straight, taking it easy on under braking and not doing that much of it anyway because of higher lat. accel. capability. The M3 has more mass, but if you're not accelerating and decelerating the mass as hard, you save energy. Same way loading your car down with passengers and luggage and cruising at normal highway speeds or big open sweeping roads still gives you better mileage than constant stop go traffic in an empty car.
