Thread Close!
Status
Not open for further replies.
Jwsy
Selling used F20 Brembo GT 6/4 Pot.
$2500 for front and rear.
Item is still on ride.
Fast deal!!
Dekit due to selling of car.
Labour on Dutch.
Lowballers won’t be entertained.
Kindly contact 93837956 for fast deal.
Fast deal!!
Labour on Dutch.
doesn't look like Brembo-GT...
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeers
Hi Rssid, What is main different between GT vs 18Z? there is seller in Carousell front 6 pots brembo 18Z at $1495
Frankly speaking I have no idea what the differences are aside from cosmetic. Both are 6 pots and will basically do 0 for your car unless you track your car.
All the bs talk about better braking is just marketing speil to get you to buy it. Stock brakes are excellent see what the monster 300hp+ 535 comes with and brake with confidence on your stock setup.
That being said if you're brakes are not well maintained with new fluid every 2 to 3 years and fresh pads and rotors anything would feel like a huge difference as your comparing knackered out brakes vs new.
Want better braking ? New pads new rotors flush the brake fluid and maybe stainless steel brake lines and people should learn to drive better.
Of course all the above is simply my opinion and not worth 2 cents so please do your own research before splashing out 2k+ on a depreciating piece of metal for cosmetic reasons.
On the same note if you're upgrading the front remember to do the rears as well. Read up on brake bias as you risk skidding and sending your car out of control if you only upgrade the fronts. Want to do something do it properly or not at all as you may make the situation worse then sticking to stock.
Selling used F20/F30 Brembo 18Z 6/4 Pot.
$2200 for front and rear.
Item already been dekitted.
Fast deal!!
Status
