Suspension-one lower than the other-help
tohallan
Hi All,
Looking at the front of the vehicle, the driver's side is approx 8-10mm lower than the passenger side. Measured from the ground to the wheel arch. Current the car (E46-320) is on the M-sports package everything is stock. Question: can the ride height be adjustable on this setup? Is is DIYable? Visually, although it is only 8-10mm lower one can tell the slight tilt to the driver side, even to an untrained eye you can tell. Any way to fix this problem, pls share.
thanks in advance.
Re: Suspension-one lower than the other-help
common in ALL bmws....nothing to worry.
Convert to left hand drive.. then you sit inside OK liao... very common like toto like that... every monday and thursday got one.
Totally normal. Looks weird only.
All RHD BMW dips on the driver side.
You want perfect horizontal height = same for all 4 wheels, then only coilovers can get you that.
'The Great White'
Apologies for the newbie question :) wow! didn't know that it is normal.... any idea why that is? cheers
both fuel tank and battery is on driver side.... so is the driver.. heheh
Steering also!
:nehnehhh:
'The Great White'
If you think yours is slanted, wait till you see Terry's. (Guni say one!)
I think the car originally was designed as a left hand drive. Imagine now your car is left and drive and you have to sit on the passenger seat, the car will be more balance... ultimate driver machine mah... kekekkekeekek.
so bimmer is 50-50 distribution front & back
BUT NOT 50-50 ONE THE 2 SIDES??
HMMMMM.........
sian already. the car looks lob-sided.
is the car "designed" to be that way where front passenger side is higher ?
