suspension (blistein)
Piravin Chandramohan
Users Awaiting Email Confirmation
Hello fello 6 series Bros out there can someone enlighten me abit more on blistein shocks for my Brother who drives just a 630i, he currently complaining his suspension right back abit gone case lower then the left and car tilted abit to right back keep rubbing his tire when he turn at times and found out his right back suspension lower then the left using stock suspension at the moment, then he ask some workshop around for original one they say agent no stock kena reccomend b8 absorber they say just change absorber enough we don't know the spring ok or not ? is there any chance spring also condem? any reccomendation is it better to get b12 ith the eibach spring or just the b8 use back stock spring? what you fellow 6er bros reccomend to do and what to expect after changing like for example very bumpy rides etc....?
my sincere thank you to everyone who read this and take the time to explain and god bless you
Re: suspension (blistein)
Not only absorber,
Top mount, arms , stabilizer link , anti roll bar bushing, need to be check also because all those stuff have rubber bushings too, just check along to avoid pay double labour when it fails again to replace it.
Stock absorber you can try ask eng soon , but so far stock spring never have such short lifespan unless the car having some abnormal impact or accidents case, else it will last till your grandson generation.
christopher ngo;1127105 said:
Not only absorber,
noted thank you very much advise is greatly appreciated will check on it thank you
123winfish
