marklee;549994 said:if it's slipping, your rpm should rise, but your speed is not, much like how you clutch in and rev.
marklee;549999 said:Then most likely it's a prob with your gearbox.
iScoupe;550042 said:gearbox, clutch, flywheel up the lorry....
bro from ur description quite sure liao la... u drive manual but ur problem sound like auto gearbox.. more like slip gear then grip again...XXX;549884 said:haha sorry let me try again...
at about 70km/h, I switch to the 4th Gear, step on gas, car continues to accelerate for about 2seconds, afterwhich it seems to lose power for about 2seconds, power seems to cut off, and then back again, and move on as normal.
find a workshop check la.. the worst will come when u @5th gear it slip to free gear soon..XXX;550057 said:So if it is slip gear, is it going to be a simple repair or need to find parts to change?
