Stone chip on bonnet
Re: Stone chip on bonnet
Soonster;455795 said:
I have a dent on the left side of my ride also... eye sore... You guys saw it right.. should be going to angie to get it fix next week...
u sure u dun wanna try PDR at capitol 1st before spraying? spray is always last resort, esp since ur car only 3 mths old.
hi bro,
For touch up paint from PML, comes with a paint coat and a clear coat. DO you apply the clear coat as well?
Audio086;459195 said:
hi bro,
i just apply the paint coat. its too small to apply clear coat. end up u might make the chip more obvious then it seems.
I just did some touch ups today. Not happy with my previous touch up. removed it and reapply again.
Audio086;459300 said:
how did you remove the previous touch up coat?
i learnt this from a paint master.
dab ur cotton swab or cotton bud (the ones u use to dig your ears) with surgical alcohol or nail polish remover. personally i like cotton buds as it is more pointed and hence the area of focus is smaller. Having done that, place the cotton with alocohol on the area u wanna remove. Apply a slight pressure and u will see the old paint coming off.
Dun worry about new existing paint around ur car as it is protected by the clear coat and even if u poured the entire bottle of surgical alcohol on it it wouldnt come off.
If you are apprehensive about the above procedure i can help u do it. hehe
Deadkookaburra;455608 said:
i have also contemplated on repairing 2 stone chips courtesy of IR trucks along ECP :( however quite relectant as the factory coat is still better than those locally sprayed.
but are u traveling behind or on the side of the truck?
most likely is behind, in order for the truck to generate that kind of force to richochet a stone onto the bonnet which would cause a chip.
u mean u predict the stone is richochet from the truck's wheels?
