Stock Sound System
uncle_catz
Hi
This is my 1st new post. I have gotten a used 09 E90 318i FL recently.
Apart from the stock CD headunit and a set of Alpine tweeters on the front doors, I am unable to determine what brand the rest of the system is.. ie speakers, amp etc. I also cannot find the amp nor a cd changer in it.
Does anyone know what is stock system as given by pml for this model car? I am hoping to kit in the speakers and amp from my previous ride.
Re: Stock Sound System
If not wrong;
- HU is professional system, same as 320i.
- Doubt you have any tweeters. If you do not have tweeter mounts on the plastic door window frame, you only have 2x4" speakers on the front doors.
- You have 2x6.5" woofers under both front seats.
- The OEM is Bosch.
- There isn't any amp installed. All the speakers are powered by the HU.
- Check your trunk. The CD changer is probably there. Another way to check if you have any changer hooked up is via the HU.
Thanx for the info & advice..
the stock system does sound 'hollow' , so i am keen to put in an amp and focal speakers from my old ride...
uncle_catz;622631 said:
Good choice...
my e90 FL comes with stock(i think) tweeter mounted on door window frame, so i guess changing that is a breeze.
its the 4" mid that i will need to consider since mine is a 6.5" 2-way components previously...
does anyone put a 6.5" midbass below the seats instead of a sub?
Bro, check out bro Humara's setup. Recently he had just got his 3-way ICE setup done. Heard his sound and sounded amazing, 6.5" is under the seat also. Think he will post his setup very soon... :)
For E9x, there are three types of sound systems: Stereo (standard), HiFi (option 676), and Top-Hifi (option 677) with 4 channels 6 speakers, 6 channels 10 speakers, and 9 channels 13 speakers respectively.
Go to BMW Model Archive · BMW VIN Decoder · bmwarchive.org and enter the last 7 digits of your vin and you can check whether you have either option 676/677. If not, then you have the standard stereo sound system.
As far as the brand, I'm not sure what the standard and 676 is, but I know option 677 Top Hi-Fi is Harman Kardon or a subsidiary of Harman Kardon because it has Logic 7, which is a proprietary Harman Kardon software. Hope that helps.
Book an appointment wif codewerz...
Coded mine... so far veri happy with the sound...
