Steel weights on wheels
Oilman
Legendary 10 Years
Folks, this morning I noticed a few of those little rim-balancing weights are missing from my wheels, leaving only the gluey bits - is that normal? Should I be getting them replaced?
Those weights were put on by the tyre shop and I haven't changed tyres for like three years... I know it sounds like a damn long time but the threads are still deep. Does it mean it's time to get fresh rubber anyway?
Re: Steel weights on wheels
As long as you're not experiencing any adverse handling or vibration, I guess should be ok? I wonder if the workshop will stick them back on the next time you get your wheels balanced..
for peace of mind, you can go tyre shop like pitstop, hurry, coco, etc and ask them to do wheel balancing for all 4 wheels with new steel weight :D
swee swee and it should not be expensive
i did that one year after change tyre. to make it swee swee again and also as a checkpoint to check the rim & tyre
then for 2nd year, change tyres (2yr = 35k milleage) and it comes with wheel balancing
