spacers
oldschool
Need help regarding fitment of spacers.. will spacers cause my car to be unstable during high speed..? driving an E36
Re: spacers
If hubcentric, if not too thick, if bolts are long enuff to secure the wheels on spacers, then the answer is no.
Re: spacers
oldschool;598628 said:
looking at 10mm probably.. where can i get those..?
i afraid that is no 10mm for your case.
best you consult the seller(local) and also best buy with installation.
some have bought over the net or oversea and selling party always claimed no problem.
you will only know the fitment correct or problem till you install it physically.
Do remember Premium quailty built spacers are all R&D base on Original eqiupment fitment (OE rim)(if you are on Aftermarket rim be more careful)
Aftermarket tuner wheel like AC / BBS do have their own factory produced spacer which is made strictly for their product used only.
Re: spacers
you can try local tyre shop (reputable on). They can customise for your dimension. IMO, dont use spacer for rear tyre if ur drive is rear wheel drive. What kenn say is true, if they can supply long bolts then its ok but do ask for extra, just in case of emergency.
Re: spacers
Brother Gadaffi, why is it dont used spacer for rear wheel drive?
my undersatanding is most spacer are for rear wheel drive.
Customised spacer is OK but most reliable one is still those branded one which has lab tested.
customised spacer you have to beware of some poor designed and material used.
mounting bolts lenght is the job of the shop whose sell and install that make sure is correct spec.
Re: spacers
it is just me as i dont feel safe with it bro.
Re: spacers
as this quote.
keywords.
hubcentric. longer studs.
Re: spacers
tomace;598798 said:
Hi & sorry to OT..
Since its on spacer, May I know which size to go for if I would like to push out my stock 18'' M rims? Im driving an E90 320 m sport.
Thanks in advance. :)
theoretically if the spacer thickness of 15mm it will change of wheel offset (push out) by 15mm (do remember our car may be left /right not 100% same distance)
example your wheel offet 20mm after the 15mm spacer it will became 5mm.
SO my advice to you is get the advice from the shop seller and with installation,
BUying cash and carry you are also carrying a risk of wrong specification.
and all automotive item are sold non returnable once installed and used.
Re: spacers
Hi roberttan, thank you very much ~~ ;)
Yes, most car (any make / model) are never 100% e same. :)
Re: spacers
Just managed to get spacers 3mm and 5mm from a workshop whom custom make them via CNC (recommended by some bro here). It fit very nicely with close fit to the center hub. Reasonable priced too.
Let me know if you need the contact. He only make 3mm to 5mm, as he claimed any more the studs must change.
Re: spacers
Hi all,
Noob qn..what is a spacer and what does it do?:thinking:
Thanks in advance for all bros who take the trouble to explain.
Re: spacers
Yeah I was thinking of adding spacers too for front 5mm n rear 15mm..got a quote of around $300++ for the spacers together with longer studs.
Will do it after I install my coilover, so i can rough gauge the spacer width...as afraid it might rub the fenders...
Re: spacers
myst17;616033 said:
Hi all,
From my understanding
Spacers pushes the rims out abit to give more leeway for the suspension. So they will not come in contact when the ride is lowered.
Bad drawing attached for (hopefully) better illustration:-
Re: spacers
Decided to retain my original 18 inch rims for my 525. Thinking of adding spacers to make it look aesthetic. Any recommendation where to get good spacers without compromising stability etc? Can spacers be added?
Re: spacers
Don't worri lah....I ran 10mm spacers fronts on my E60 for 5 track days at Sepang w/o any issues.....
'The Great White'
Re: spacers
I have brand new 1 set 10mm spacers with longer bolts in stock.
'The Great White'
Re: spacers
Where can I get 5mm spacer for e90? Boss only has >10mm.
