Spacers... disadvantage?
Re: Spacers... disadvantage?
i am on eibach spacers- so far so good!
dude, its good, no downsides...get the Rogue Engineering hubcentric ones, put 12mm behind..
perfect!
im on 10mm...12mm will be juz rite...
i am on eibach too ...so far so good.... too....
Hi i got the Eibach 12mm....
Looks good!
BUT....... it hits the fender a bit when i am travelling on expressway (bumpy part).... i can see on my tyres a bit of white lines( white car)
Any solution?
1) adjust your camber to make it more negative
2) get your rear fender flared
3) change to smaller spacers
4) increase your ride hide and use stiffer springs
5) change your tires to one with a rounder sidewall
just some possibilities... you can use in isolation or in combination.
HI what do you mean by fender flared?
How much would it cost and where can i get it done........
roll yr fenders at Lye Design, Ang Mo kio autopoint...
same floor as riverview...
how did they do it? issit safe on the paint?
Downside? No have leh.
Me got BBS 1cm spacer at the rear, no rubbing whatso ever worrr.....but then I didnt lower my car so maybe thats why. I heard from the brother where I got the spacers that the main thing is u gotta make sure the bolts which are used for fitted the rims are long enuf to be able to take the extra space. ie if used 1 cm spacer then the bolt shld be at least 1 cm longer than the ones used without spacer. Otherwise it seems that there will not be sufficient screw thread contact to firmly secure yr spaced out rims.
