Some interesting details on tyres, rims, brakes
centurion
Just some random musings on anal stuff from so many hours in tyre/rim shops....
When mounting wheels, lubricate the wheel studs with lithium grease before torquing
Why lubricate? 2 reasons. So they won't seize, prevent rust, and so that it's smooth enough so that when you torque the lug nut, the resistance against the torque is from the stretching of the stud and not from the rust and dirt.
Why lithium grease? Normal grease can or not? Normal grease can, but it will not stay. The moment your wheel gets hot, the normal grease melts and flows down and sprays around your wheel everywhere. When no grease in the lug nut then the rust prevention will not happen.
You must torque the lug nuts
Why torque? Can't just use `feel'? NO. torquing will equalize the tension of the wheel studs, so your wheel hub, rotor and wheel all clamped together same force all round. If the force not the same, thermal expansion will distort stuff, particularly the rotor, and cause brake judder in the long run.
You must clean the wheel centre hub once you dismount the rotor with brake fluid
So that no dust or rust interrupts the smooth interface between the wheel centre hub and rotor. Even a few microns of rust or dust will cause run-out in the rotor, the bigger the rotor the worse. This run-out will cause judder and vibration over 3K km thereabouts.
Don't use the air gun to torque the wheel lugs
The guns usually have no torque control, even if they do, they are impact wrenches and the torque control is not good. You need a steady pressure for torque.
Re: Some interesting details on tyres, rims, brakes
Great tips Centurion!...sad to say, not many tyre shops will "lovingly" do as you suggest!!
Yup... not many tire shops use torque wrenches to tighten our wheels
Centurion,
Which tyre shop do u go to?
honestly, I do it all myself. I go all places, Poh Heng, Yap Bros, Leong Seng, Kian Tiong, eSpace. Only Kian Tiong and eSpace will do it for you without asking, LS and YB will do it if you ask, and PH does not 'seem' to have a torque wrench - I had to supply my own.
If a shop dismounted my wheels, and put them back without me, I untorque the wheels when the wheels are on the ground, and I torque them back by hand, 110Nm for the Odyssey and 130Nm for the Porsche.
For brakes, I have to make sure I'm there when they remount on the wheel hub. They refuse to blow the wheel hub, so I have to supply my own cleaner wipes, then they use a rag with brake fluid to wipe the hub, and I will supply a clean rag to wipe it all out.
eSpace does it all lovingly like that, and I love them. Andy is great. He has a more precise gauge of lithium grease than I can even find.
Another word about torquing. You can't rely on 1 torque session.
You torque first.
Go drive 1km.
Then torque again.
One more thing - about breaking in / bedding in brakes.
Don't let the shop do it.
YB has a China national guy who's a butcher. He fixes the brakes then goes for a round with your car. He heats them up to high temp IMMEDIATELY without gentle braking, and brakes violently straightaway and then say bedded in.
NEVER LET THEM DO IT FOR YOU. Brand new rotor 335mm COMPROMISED because of this guy. Never again. Do it yourself. The trick is GENTLE heat introduction.
Where to get torque wrench? I searched everywhere, but found 1 shop at Jalan Besar x Dickson Road Google Maps buy the biggest version.
Good tip...
but 98% of the mechanics dont really care about these things. good to find a wksp that does.
ive tried the following
Poh Heng (Fast, cheap pricing, but kinda sloppy work, no torquing)
Ray S (fast, average work, no torquing)
Stamford (rotated tires, did torquing, average)
Nankang at 176 sinming ( rotated tires there, average)
Leong Seng (current favorite, professional-looking balancing machine and alignment, with torquing, nice shop owners)
Will try Espace on my next trip.
15
I'm going to bump the thread PRETTY WOMANPART 15INT. BROKERAGE HOUSE - DAYEdward is walking down the hall. Stuckey comes out of theoffice and calls after him.STUCKEY(calls)Edward, what happened? What kindof move was that?Edward silently goes into the elevators. The doors close.STUCKEY(yells)Dammit Edward, speak to me.Stuckey heads back to the conference room.EXT. OFFICE BUILDING - LATE AFTERNOONEdward comes out of the building. His Chauffeur leaps to openthe limo door.EDWARDNo... take the car back to thehotel. I need to walk.He sets off across Century Park East.INT. PENTHOUSE - EVENINGVivian is in the living room, pacing, edgy, the doorbell rings.She turns. It rings again.She opens it. Stuckey is standing outside with a smallbriefcase. He looks agitated. He tries to hide it.STUCKEYWell, well... Hello again. I'mlooking for Edward.Vivian just stares at him.VIVIANEdward's not back. I thoughthe was with you.Stuckey walks past her and down the steps into the living room.STUCKEYNo, I'll just have to wait then,won't I?There is a bar set up. Stuckey sets his briefcase down. Hecrosses to the bar.STUCKEY (cont'd)Mind if I have a drink?VIVIANNo.He pours liquor in a glass. He fires it down. It seems tocalm him a bit.STUCKEYDo you want to know what he did?Do you want to know what the crazyson of a bitch did? He handedthe whole thing back to Kross!On a silver platter. For noreason! What was he thinking,I mean, what was going throughhis goddam head? Why?(pours another drink)What was all that benevolentcrap? What are we going tobecome, a philanthropicfoundation? I'll probably be thedirector of several worthwhilecharities.VIVIANI think it's great.Stuckey glares at Vivian.STUCKEYI bet. A lousy whore and you'rethe gum in a hundred milliondollar deal.VIVIAN(mocking)Aw, come on, Bill. It's justbusiness.He looks at her a moment.STUCKEYBut what do I know, maybe you'reworth it. Come on, show me.Let's see your act.He grabs her wrist.VIVIANGet out!STUCKEYDon't worry. I'll pay for it.What a you charge? Huh? Twenty,thirty, fifty bucks, maybe? Areyou a fifty dollar whore?He tries to kiss her and pulls her down on the couch on topof him.VIVIANAre you crazy?She bites his hand. Stuckey slaps her. Vivian starts flailingback. But Stuckey is too strong. Vivian staggers back at theforce of another slap. Stuckey slams her up against a wall andstarts rubbing up against her.STUCKEYYou got a mean streak in you,don't you.He tries to kiss her again.STUCKEY (cont'd)Is that what he likes about you?Huh? Answer me!And suddenly a HAND lands on Stuckey's shoulder. Stuckey turnshis head, startled.INT. PENTHOUSE - REVERSE ANGLE - STUCKEY'S P.O.V.Edward, murder in his eyes, belts Stuckey across the room.INT. PENTHOUSE - NIGHT - BACK TO SCENEStuckey falls on the ground. Edward rushes forward, berserkwith rage, to hit Stuckey again. His fist hits the top ofStuckey's head, hurting Edward's hand more than Stuckey's skull.Vivian rushes out of room to bathroom. Again Stuckey triesto rise. Edward kicks him in the butt, sends him headfirst intothe bar. Glasses and bottles CRASH to the floor. Stuckey againtries to rise. And collapses. Edward rubs his fist. They'renot used to this violence and both stare at each other panting.STUCKEYYou broke my nose.EDWARDI think I broke my hand.(a beat)You're fired.STUCKEYEdward, we've been together tenyears.EDWARDAnd I don't like what we'vebecome. I'll cover any lossesyou have on this one. Now getout, you asshole!STUCKEYAll this because of that whore!EDWARDYes.Edward pushes Stuckey out the door and throws his briefcaseafter him.STUCKEYEdward, think about what you're--Edward slams the door in his face. Edward stands there,reflecting on what he's done.EDWARD(to himself, almost proud)Well, I didn't plan that!INT. PENTHOUSE BEDROOM - NIGHT - LATEREdward holds an icepack to Vivian's cheek.VIVIANWhy do guys always know how tohit a woman? Right across thecheek, wham, so it feels like youreye is gonna explode. What dothey do, take you all aside inhigh school and show you how?It pisses me off!EDWARDNot all men hit. And no one isgoing to hit you anymore.VIVIANRight.(softening)You're quite the Sir Galahadtoday, aren't ya'?(a beat)I heard what you did with Kross.EDWARDIt was a business decision.Vivian looks at him.EDWARDI got tired of hating my father.VIVIAN(a small smile)It was good.EDWARDIt felt good.Edward looks on the bed at her suitcases.EDWARDYou're packing.VIVIAN(nods)I'm leaving.(a moment)Don't ya see? If I stay withyou like you want me to, there'llalways be some guy, your friendseve, treatin' me like that...thinkin' they're allowed to. Whatare you gonna do, fight'm all?No. I'll take my money now,please.A moment. Edward reaches for his wallet. He counts out bills.He places them in Vivian's suitcase. He puts his arms aroundVivian.VIVIANAw, don't... no...EDWARDStay with me tonight. Notbecause you're being paid to.Stay with me because you want to.VIVIANI do. I do want to. That's whyI'm leaving.(turning to him)That's what you given me, see?I know what I want now. I wanta guy like you for real. Notbecause you buy me things and giveme money. The nicest thing youever done for me is hold my hand.You gonna give me that?Edward is silent.VIVIANI didn't think so.EDWARDVivian...VIVIANIt's not your fault. You'reright. Kit's right.(looks him right in the eye)But I want the fairy tale.INT. HOTEL LOBBY - EVENINGVivian comes out of the elevators. A BELLMAN sees her andsprings forward, reaching for her bags.BELLMANLet me take those, miss.VIVIANThanks.Vivian sees Mr. Thomas behind the front desk.VIVIANI'll be out front in a minute.I got a cab comin'.The bellman moves away. Vivian walks to the front desk.VIVIANHi, Barney!MR. THOMAS(looking up)Miss Vivian.VIVIANLook I just wanted to saygoodbye.MR. THOMASMr. Harris doesn't check outuntil tomorrow.VIVIANYeah, well, I check out today.MR. THOMASYou're not accompanying him toNew York?VIVIAN(lightly)Come on, Barney, you and me livein the real world.(a beat)You don't know how to treat a girllike anything but a lady, Mr.Thomas.MR. THOMASCertain ladies make that veryeasy... Vivian.(turning to the desk clerk)John, call a limousine for ourguest, please. Have it take heranywhere she wishes to go. Billthe hotel.(turning back to Vivian)See you again sometime soon.Vivian smiles softly at him. She turns and walks for the door.   Most of us take life for granted. We know that one day we must die, but usually we picture that day as far in the future, when we are in buoyant health, death is all but unimaginable. We seldom think of it. wow gold, The days stretch out in an endless vista. So we go about our petty task, hardly aware of our listless attitude towards life.  The same lethargy, I am afraid, characterizes the use of our faculties and senses. Only the deaf appreciate hearing, only the blind realize the manifold blessings that lie in sight url=http://www.wowgoldvip.fr]wow gold[/url]. Particularly does this observation apply to those who have lost sight and hearing in adult WOW Power leveling life. But those who have never suffered impairment of sight or hearing seldom make the fullest use of these blessed faculties. Their eyes and ears take in all sights and sound hazily, without concentration, and with little appreciation. It is the same old story of not being grateful for what we conscious of health until we are ill.  I have often thought it would be a blessing if each human being were stricken blind and deaf for a few days at some wow gold time during his early adult life. Darkness would make him more appreciative of sight; silence would teach him the joys of sound. WOW Power leveling Now and then I have tested my seeing friends
