mybmmer318
Guys, can our car run w/o O2 sensor? My car previous 2nd owner did some change form stock extractors to Hiop and i notice that the bottom downpipe thats connects to the cat is welded on,which tells that the whole system has been modifed and the best thing is..i did not see any O2 sensor connected to the pipes @ all. I saw the stock diagram that the O2 sensor shd be connected to the downpipe area nearest to the cat convertor but now there is none. Even the Hiop headers O2 sensor position is seal off..was wondering if no O2 sensor how come engine check lite never come on? i am still monitoring the fuel consumption but from the "65" litre mark it drop to slightly below the "60" litre mark and i did ard 60KM..wondering if there is no O2 sensor present or the sensor is short to ground which prevent the ck lite from appearing the dme will be fool and makes the car run rich which = high consumption?
Any gurus can advise if no O2 sensor present what will be the effects for the car? Currently ride is smooth but i can sense that the fuel sips like water...
