Rotor Disc for E90 LCI
My Rotor Disc is worn out. Am thinking of changing to a drilled or slot type rotor but using back the original caliper and brakes (since I just change my brake pads!)
Is there such rotor in the market available?
Where I can get it and how much?
Mine is E90 LCI
Thanks for the advise!
Re: Rotor Disc for E90 LCI
Eng Soon carry 3 grades, original (solid), OEM(solid), racing(drilled and slotted), depending on make and model, the price is SGD 50/piece difference from original, OEM(SGD 90/pc), BMW SGD 140/pc, Racing SGD 190/pc, estimate as the price is actually soften due to drop of Euro currency.
Using and rather satisfied with the racing piece as it perform very well.
Thanks for your info!
Will check with them...
Any recommended place to install and how much?
Evil Devil
Thanks for the review ! prices vary for different models. Do pm us for details.
THanks
Evil Devil
Cybercars Workshop. One side labour about $40.
evil devil;1109104 said:
Mine is E90 LCI
Hallo
It depends on your usage ... ie for looks or for better bites, heat dispation ...
I suggest go for slotted type ... bites
Call Eng soon for stocks ....
Usually it is better u change rotors n paDS together as there might be uneven wear causing vibrations when braking...
Get a goodworkshop to help u in the braking in since you like to save on the pads ...
All the best n enjoy ....
Next u might consider better pads for better bites....
Haha
