Replace shock absorber
Beerbelly
Went to replace 4pcs of shock absorbers, a pair of control arm and lower arm and front disc rotor plus brake pad yesterday. Ws charge me $360 for labour for all the parts changed consider reasonable?
Re: Replace shock absorber
seanskye;1056718 said:
Did they do proper bedding?
Am curious how would the workshop bed the brakes? Unless they take the car out for an extended spin?
Why need to compare labour charge when the job already complete?
Just like buying underwear, as long as i m comfortable, slightly more ex is still ok.
seanskye;1056747 said:
Positive...
I see. Seldom see workshops doing that since you need long roads, time and lack of traffic to do that. Can advise which workshops do that for customers?
For brake bedding - either you do the gentle braking method over an extended period or you resort to the series of sprints and hard braking (which some claim to be better), either way I doubt most ws would do for you.
Yup, thats why I was curious which workshop does this for the customer. Their service would be top class in that case.
Really? Then our site sponsor workshops must be top class!!
I am suitably impressed by them in this case. Can PM me which are the site sponsor workshops that do this? Will recommend them.
Please send me the sponsor workshop too. Thanks a mil!
The sponsors workshop.address are widely available here. Just a simple search will do.
When i change brake pad at R2D, rodney will bed in the brake pad for me.
After any work done, he will drive the car out for a test run before handing over.
Just drive easy for first hundred km, after that do some hard braking should do it.
Had some sounds from rear brakes recently after change of pads and rotors, some recent hard braking cured that :)
