Removal of leaves
fgchong
Need advise on how to remove the leaves stuck at the bottom of the radiator.
Thank you in advance. FG
Re: Removal of leaves
Not sure, can try vaccum cleaner?
get a pair of food court wooden chop sticks and tape it together at both ends to create a longer stick. wrap double sided tape on the tip of one end of the stick and poke through the gauze before the radiator and the leaves will be stuck to the tip. Pull them out one by one.
:lol2: :lol2: :lol2:
Tks for all the suggestions. Can I remove the front grill to assess to the stucked leaves?
you prob could but its not something you could do without dismentaling more stuff. suggest you dun.
Appreciate your advise. Will do it probably during my next servicing.
just cut 12" hose and attach to vaccuum cleaner and suck. Do it today. They corrode the radiator.
i just use a hose to spray at the radiator, most of the time they will come out....
i wash the car every week so the leaves will come out pretty easy
I did the same too! :)
Will try this weekend. Thank You
i will think if u wash ur car every week, the leaves will be out pretty easy by using a hose to spray at the radiator.
the leaves do fall off from the radiator area but does it actually get collected somehwere at the bottom? i.e, does it get flushed out from the car? Does not look like there are any outles below.
tatsit;427169 said:
i use my fingers to take the leaves out one by one...
Terry will love to bring you home. Haha.
Anyways, back to the topic.
I wash my car everyday... Simply use hose and spray them out. Not a problem. Some might get stuck at the grill... Den like what tatsit said... Use fingers lor.
not sure abt e46, Herman. but for e90 the leaves are stuck at the radiator, fingers has no access to it unless u dismantle the bumper...:)
hi bro
the way i do it is whenever i go to workshop , they have this air pressured jet that they use to jet blow the engine surface when they finished the car service or they use it to jet blow the air filter.
use it to jet blow where the leaves were. it will goes off.
regards
