Red H8 Bulb
markbmw
Does anyone know if it is possible to get a red h8 bulb in Singapore or anywhere in the world ?
Looking for it for quite awhile.
If not possible, is it ok to wrap a red translucent paper over the bulb ? will it get burnt ?
Thanks,
Mark
Re: Red H8 Bulb
red i doubt anyone would make them. blue, yellow, white yes, red no
if you cover in cellophane, it will burn in seconds.
red is for tail lights mate
Re: Red H8 Bulb
That'll be hardcore! haha! Think shinobi from e46fanatics did it before...
Re: Red H8 Bulb
yeah, ive seen it before too. But it is probably a H4, or something similar. H8 is fairly unique. So, supply and demand i suppose!!
Re: Red H8 Bulb
actually, i want to get it to replace my e60 Lci angel eye bulb to get this look.
initially i thought that it was the same bulb as the pre-facelift version. therefore, i ordered from car-gym. until i tried changing it at BVO two days back, then i realised that the facelifted e60 actually uses H8 for angel eye.
so there is practically no way to get it red ?? heat resistant spray or anything possible ??
many thanks,
mark
Re: Red H8 Bulb
Just to share some experience....
Currently mine is E60 facelift using H8 bulbs for angel eyes.
Didn't like the yellowish stock color; wanted to change to white or blue....
Red may not be legal in Singapore??
Tried Autobacs, only had white bulbs (no brand), cost ard 20 bucks. Color is ok but dimmer. So used them for my fog lights which turned out ok.
Had searched the net b4; found on ebay a slight bluish white bulb (luminics). However, color is still dimmer, but better than the local ones. So used them on my angel eyes. For some reason the intensity of the stock bulbs are higher, even tho all of them are the same at 35 W.
Hopefully someone can come up with something better. LED will be great!
Re: Red H8 Bulb
largest no. of LEDs is 36pcs.
Re: Red H8 Bulb
Will it trigger off the i drive error code?
How much for the blue ones in H8?
