Rear Trailing Arm Bushing Limiter Kit
wilman2772
Legendary 10 Years
Applications: 1992 - 2005 318, 323, 325, 328, 330, M3 (E36, E46)
The rear trailing-arm bushing limiter kit creates a stiffer suspension without sacrificing ride quality.
These kit is a perfect upgrade from stock without the harshness of "race-only" bushings.
By combining these limiters with stock bushings, this is a great low cost and effective suspension performance enhancer.
By limiting the amount of side-to-side movement of the stock bushing , drivers will have increased driver feel because of the reduction of toe variation due to the squirm of the stock rubber bushings.
The bushings will also have longer life. This is also an advantage because many BMW’s have issues with the stock bushings ripping and tearing over time.
Some stock class racing series even allow this kind of modification, because the stock bushing is still being used.
Kit includes: 4 aluminum bushing limiters, eight 5mm allen bolts and a drilling template.
Please contact BVO if U guys are interested!!
Cheers!!
p.s. : I install liao....... :twisted:
'The Great White'
Re: Rear Trailing Arm Bushing Limiter Kit
MRacer77 said:
Bro, sure can fit M3 or not?
Should be ok U know!! Cos the support bracket is the same part no. as non-M cars!!!
Only diff is the rear bush itself....M cars should have a stronger/stiffer bushing!!
Go lup in this limiter kit & U'll know wat I mean!! :cloud9:
'Clan Master'
Cheers!!
'The Great White'
Bro, buay swee..never tell me before hand..
Wah lau eh.....BVO just got this done 3 weeks ago....U not around mah.....
Go get it done!! Only S$280!! Price includes the limiter kit, installation labour charge & full computerised alignment after install!!
:dance:
'Clan Master'
:dance:
'Clan Master'
Swee2x! I go down BVO this week! Kum Xia!!
Sorry for asking......so what's the difference between this and sway bars?
Sway bar is to reduce body roll when cornering...the car corners alot flatter... :)
This one u must get lah bro...get the GenII lor..swee2x.
Toot! Swaybar is to prevent the car from rolling/dipping like the pic below...
This kit is to limit the amount of side-to-side movement of the stock bushing , U will have increased driver feel because of the reduction of toe variation due to the squirm of the stock rubber bushings. The bushings will also have longer life. This is also an advantage because many BMW’s have issues with the stock bushings ripping and tearing over time.
Clearer now??
:nehnehhh:
'Clan Master'
Wil, this is the one that u were telling me about last sat right? About the wheels having less travel?
Yes sir!!!
mai tu liao!!!
'The Great White'
Clearer now??
:nehnehhh:
'Clan Master'
So which is more important to get first?
Wil,
Me toot too. So what is the diff between swaybar and ani-roll bar? Or are they the same thing?
They should be the same thing
T6 said:
Wil,
i even more toot... swaybar and strutbar does the same thing ? just that one below, the other on top ?
pls advise...
Swaybar 1st!!!
'Clan Master'
T6 said:
Wil,
They're the same!! Diff way of calling, tat's all!!
'Clan Master'
pls advise...
Ok toot!
Strut bar is on the top....it's for the rigidity of the chassis
Sway or anti-roll bar is for roll loh......
Clearer now??
'The Great White'
wilman2772 said:
Swaybar 1st!!!
'Clan Master'[/Q
Thanks bro
