RE: Notchy Auto Gear Box
FiftyFive
:confused:
Folks... kanna tonight...
When shifting from "D" to "S"... a notchy feeling is felt...
Any comments and advice is very much appreciated...
Thanks
Re: Notchy Auto Gear Box
Sounds like the "special meat" effect has also spread into your gearbox system
Maybe U never use this.................kekekeke
Racing ATF
Designed for use in racing automatic transmissions which need the positive shift of a Type-F automatic transmission fluid, Racing ATF contains no slipperiness additives, producing faster shifts and quicker lock-up, and can reduce elapsed time in drag racing.
A higher viscosity compared to conventional Type-F transmission fluids provides higher torque converter efficiency at higher temperatures and the enhanced extreme-pressure protection provides five-times better film strength when compared to petroleum ATFs, reducing gear and clutch wear considerably.
This product can also be used in manual transmissions which require ATFs, providing better gear wear and better shiftability, but Red Line MTL® will provide even better wear protection and shift action.
'The Great White'
Car having withdrawal symtoms.. too long no go Sepang liao.
