Question with regards to car servicing
Arkantos
My car gg for servicing tomorrow, at 20K km. Advisable to do wheel balancing or just alignment will be fine? What is the expected cost? Doing at PML Alexander.
Thanxs
Re: Question with regards to car servicing
Thanxs
Hi Arkantos,
why do you need to do wheel balancing or / and alignment? did you just change tyre?
i think do outside shop like hurry tyre better. pml i scare...
Hi ac323, nope, didnt change the wheels. Just thinking whether is it a common practise to do it, to even out the wear and tear.
I presume it's rotation.
Nevermind, whichever, the answer is the same, do it outside.
Hi Robot,
if on Staggarred set-up then should be swop right not rotate?
* you are right do it outside........
Hi Arkantos,
you check with PML if there's not charge for doing rotation then let them do it........
unless is doing wheel alignment and high speed balancing then can do it at an outside workshop.
Thanxs, folks frr your advice. Since this is the first time Im gg for 20k km service, what is the standard things to do durinf servicing besides oil change? Dun wan to do non-standard stuff
Thanxs
ac323;575007 said:
Hi Robot,
I didn't know Arkantos is on staggered set up....
Btw staggered doesn't mean can swap also....
Ok sun disturb me liao, i'm saving the galaxy now and fighting darth vader on channel 5.
can la, swop from left with right.............
yup, Star Wars weekend
Thanxs
Hi Arkantos,
Standard Scope
Oil Change
Power Steering Oil
Set Oil Filter Element
add Washer Additiives
Just did the servicing.
Also took the chance to have a close up look at the F10. Externally, look too identical to the 7 series, dun like the front grill design. Interior wise, certainly look better than the E60.
Looks are subjective though.
