question on DCT torque limit
dcs2k
hi guys have a quick question here. Is it true all the DCT cars have a torque limit of 375lb/ft? And if so, what if the reflash/piggyback is giving me more that that amount? Any way I can increase the limit with a transmission reflash ?
Re: question on DCT torque limit
A dreaded question asked 2 years back worldwide by ZF gearbox owners. 2 years since, many are still running torque levels way above those ZF stipulated threshold level.
Not sure about DCT, but 375 lb/ft is 500 NM, way above the supposedly 450 NM threshold on the ZF.
Flash or piggy, the thing to watch is the torque spike and the boost levels. Yield on the N54 is great, but watch those PSI levels. Above 15 PSI (about 1 bar), those wastegates will be at risk.
ZF gearboxes can take 20%+ above their recommended limit.
also depends on how u drive...release throttle slightly before changing gear will def prolong it.
thanks for the most informative post guys. It is very reassuring to know that many people ran above the torque limit and everything is still going on strong.
kwy91 yeah its juiced :D
just a bit concerned about any long term adverse effects of running it with hgiher boost and all.
Keep it within or at most 15 PSI and you will be fine.......
Yes, listen to Kenn, or else BOOMZ!
hi all, i'm going to ask a very elementary question.
what is DCT and how does this new transmission work? i mean the pros & cons as compared to the older transmission.
any pointers in any direction is greatly appreciated.
you all la, never tell ris low to heed Ken's warning, now she BOOMZ BOOMZ!!!
hi tofumonkey, im also a noob when it comes to this, but heres a link , hope it helps!
im new here. Just curious...how and where to do reflash on ecu for Z4 Si35? How much does it add to the car in terms of torque and hp?
thanks alot dudes
Niva said:
thanks alot dudes
How?
JUICE BOX 335i PERFORMANCE TUNER
Where? Boss Motorsports. Look for Dr Dre "fuzzy" ......
dcs2k;483027 said:
JB3 is the way to go man..100% agree..
Dan, dyno machine up oredi, dng next wk, wanna go? Give me a shout.
im good any day! :> how does tomorrow after 12 sounds?
