Query on On-board Computer Stick for E46 FL
Playtennis
I was wondering if it's possible to transfer the On board computer stick from one car to another? Is it a very difficult task? Has anyone done it before? :thinking:
I am keen on getting one but is not ready to pay PML for the 'BC' stick. Any bros dekitting the 'BC' signal stick from their E46FL 318? Can make me an offer.
Jenn :)
Re: Query on On-board Computer Stick for E46 FL
Yes, it is possible.. in fact it is an official add on option in the e46 brochure.
The stick will cost a few hundred bucks if buy from eng soon. Not sure installation will cost how much. Have been wanting to do so for a long time but have not done so.
hi xuexun, this is mainly on the programming needed also, i believe? seems interesting... just buy the stick + install? nothing else? cos if so easy and couple of hundred, reali worth considering... have you done it? wanna guinea pig? or 2 guinea pigs together... hmmm... ;) any idea who's doing it? (dun wan pml to touch my car, so i guess its either bvo, or j4c...?)
Playtennis;179704 said:
Jenn :)
Yes, you can. I've done that on my old ride at BVO, need to add some code only.
hi Calvin, thanks for the update! btw, i'd like to do it too. what do i have to buy? n maybe if not convenient publicly, can u pm me how much ur damage was? (cos mod bug still biting now... especially for interiors, cos exterior mods sometimes damage beyond my control, so trying to minimise on external, max on internals...) anythin other interesting projects you embarked on for interiors?
Hi Calvin,
Can you let me know the estimated cost for the entire operation of fitting the BC stick too? Thanks.
Jenn :woottt:
Playtennis;181105 said:
Hi Calvin,
Jenn :woottt:
Hi...
I do not know how much the OBC stick selling in PML now... I got mine from MW, cheap, just a token... :yummie: you guys maybe can try to get from those bro who gog to export their ride...
as for adding the code, you guys may check with BVO-Bernard... or PML, they do the code as well. compared the price.. I did it few years back... very simple job.
Hi all,
Has anyone done this recently?
Thanks and sorry for bringing up this old thread. I wonder whether propel has these stalks available....
I know someone personally who bought the stick and the installation from PML... for SGD $800.... if that helps anyone.... i suspect not! :)
Hi Henry,
So it means any 318I can do it. Its just a matter of getting the stalk right?
Thanks!
vegadonovan;274122 said:
Hi Henry,
Thanks!
Yes ! My 318i has the OBC :)
Not a must but pretty good to have :nehnehhh:
Er.... What does this do???? What is it for???
Hi Bentai,
It can do all the below....
Hidden Onboard Computer Functions
There are a number of "secret" OBC functions which can be enabled to display raw data output on the digital odometer. Some are found during standard operation (e.g. average fuel economy), but many others are unique to the "hidden" mode (e.g. engine speed or vehicle speed).
Note: these functions will work on ALL US-spec E46 cars, even early 323/325 models which are technically not equipped with the OBC option. The OBC is in fact installed and operative in every E46; as an option, it can be "retrofitted" (activated) by installing the OBC-style turn signal stalk and activating the appropriate trigger during an ECU reflash. The better dealership service departments will know how to do this.
Instructions to access the hidden OBC functions:
1. Hold Trip Reset while turning ignition key to on position
2. OBC should show "Test"
3. Use Trip Reset to select function 19.0 that unlocks all the features
4. Wait for display to show "Off"
5. Depress Trip Reset for 1/4 second and release it
6. With no delay press Trip Reset several times to select one of the following function s
BMW E46 On-Board Computer (OBC) Hidden Codes
example description
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) **-revision index (44)
-- 2 (test) Cluster System Test - Activates the gauge drivers, indicators and LEDs to confirm function -- 3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
-- 4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
-- 5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
-- 6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
-- 7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
-- 8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
-- 9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0 Status Digital Outputs (bits) 0=inactive, 1=active 1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot --
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
