Problems on car exterior lightings.
cjohntoh
Hi ,
Anyone have problems with the warning lights from the onboard system before?
I have check all lights , but there is no fault.
When to workshop to reset , check all lights , but the warning lights still comes up.
Anyone encounted this issues or know how to solve this problem?
Thanks...
Re: Problems on car exterior lightings.
Did you Check all your front and tail lights.
That includes brake lights, high beams, signal, etc
Hi nnb239, yes I did check. All lights are working..
In some of the lights, like the tail lights and brake lights there are actually 2 bulbs in each side. One is a standby when the other fails. In your case one of the bulbs has failed and the spare has taken over, which explains why you can't see it.
I had this once before in my brake lights, and the above was explained to me by the SA at PML.
Noted. Thanks.
Further to what I wrote, I just found out the following:
When you do a Check Control and it is showing the lights fault, press the BC (Board Computer) switch for a few seconds for the Check Control ID code to show. Go to the internet and search for the CCID Code List to see which light is faulty.
Thanks, will try that...
