Pre FL & FL 320cab
reisa
Hi.. Anyone know the difference between a pre-facelift 320ci cab and a facelift 320ci cab?
What to look out for when buying a used 320 cab?
Please let me know... thanks...
Re: Pre FL & FL 320cab
Pre Facelift:
Facelift:
The differences are:
1) front & back bumpers.
2) FL has LED back and brake lights (PFL uses bulbs).
3) Front lights are different. The shape is different and the FL one has projection light.
Mostly external differences.
When buying a cab make sure that the soft top mechanism is working fine and that water do not sip in when the top is up (to test, spray water on the car). Hope this help.
The interior trim is also slightly different, as well as the location (and shape) of the little side indicators. On the outside, 320-330 should be identical.
Thanks for the Info guys.
Btw, do u know where can i buy the angel eyes headlights?
Is there any recommended brand for quality?
You can buy the angel eyes and fix it to the stock headlights. I think some members are selling them. Check out the assessory/parts section under Used NMW/BMW Parts.
