soulaffection
i'm really new to this so pls help me out here... i want to change my lights to those bright white lighs that you see a lot on the roads nowaday but i don't know which type to choose cos apparently there are quite a few varieties.. mine's a 318i (1994) btw..
these are for the headlights:
5000k dazzling white light output
Outstanding light output performance with same power consumption
UV-block quartz glass whihc is safe for plastic headlights
Direct replacement, no need for additoinal parts and wiring
HIgh light output - 300% brighter than standard halogen blubs
Low energy consumption, 50% of the standard halogen bulbs only
Longer life- up to 2500 hours; almost equal to car life
Best "High color temperature" bulb in terms of light performance
UV quartz glass provides total protectionfor headlamp reflector
UV blocked-safe for plastic headlamps
4300k stylish white light output, enables driving with confidence
Better refelctions from road marks and signs
UV blocked quartz glass which is safe for plastic headlights
Complementary sidelvight for total headlighting upgrade
Direct replacement, no need for additional parts and wiring
Up to 50% more light on the road
10-20m longer light beam
Better reflection for road making and road-signs
UV blocked quartz glass provides total protection for headlamp reflector
Fully compliant with ECE R37
i don't really know the differences except that some are probably brighter... and which is better or nicer? cos i dun wanna waste money for something lousy although it may not be much la but still all the time wasted getting it done.. i wan my car to look more sporty so i guess the lights should be bright..i saw a car that day that had really nice lights..it was a really nice strong beam that really made the car stand out.. so if anyone can help me, pls do give me ur opinions before i make a final choice... thanks!
