Plan to get 2011 E90
ericmetta
New Member
hi guys,
Metta here... have plans to get a 2011 E90.
But also heard alot of horrors about Bimmers...
Still contemplating though.
Regards
Emetta
I have a e90 2011. 325 69,000km.
All good
You just need to check for a few things to be all ok check gearbox if smooth, any steering knocking sounds upon bumps, engine smoothness.
If all ok can buy.
Then Change atf, front control arms, valve cover seals set, pcv hose, ignition coils, spark plugs, water pump and you should be ok. Until 2021. Ten years
That should give you peace of mind
This is my fourth 3-series since 2000
16 years of BMW. Still smiling when I drive it.
Stop smiling, then sell it
Get codewerx tony to check it before purchase.
Ok thanks bro
All good
If all ok can buy.
Bro,
So how much you reckon will the damaged be for the above mentioned?
Thank u
Yes. 335 are turbos. So
Consider to also check and may need to also change charge pipes, wastegate for turbo cars.
And check vacuum lines for leaks. Pcv too.
