hi everyone. My car recently has this overheating fault, after bringing to the workshop to change the waterpump, fault still persist. Anyone knows what else are the possibilities?
Is your water reservoir level enough? Normally after waterpump replaced, the next day before engine start have to check again for the level so to ensure it enough.
Sorry for the late reply. The problem does not falls on waterpump not radiator. Its my oil level sensor that is giving out false info. After changing the sensor its back to normal!
