Need Help! E92 335i N54 2009 Engine Stalling Issue Intermittently
b@yerische
Guys, need advise on this... What could be the issue? Sometimes car goes into "lymp" mode and subsequently engine stall while driving...
Looks like your fuel pump is failing, understand it is quite common.
Is there an improved version or after market fuel pump that can solve this issue?
just go back stock its good enough. and limp mode could depend on other things. is it during WOT?
if so could be due to leak in hoses etc.
No, I was slowing down for a red light and went lymp mode. Follow by a stall when I was coming to a halt. Lucky I was not on highway...
I had the similar issue last year and two things the mechanic did - to tune up the RPM a bit higher and the next thing was the change of the fuel pump beneath the rear seats. The problem resolve and no recurrent till today's
