Need Help & Advice
initialM
Guys,
I bought brand new Bilstein B8 all four for my E46 from Eng Soon, SG.
After installed & using it for bout 1 month & half (around 2k km mileage usage)
found out the front right absober is leaking badly. Called them & was told to bring it back for checking. So I replace the leaking absober wt used absober & bring it to Eng Soon hoping to get 1 to 1 replacement. As to my surprise they told me to buy a new one & they will send the leak absober to Germany for factory checking after I fill up claim form. If it proven to be manufacturing defect they will return my money. It will take at least 2 to 3 months Added to my anger the Fatty Boss even tell me that the shaft still can go up after pressing it to test KNN. He think I'm an idiot arr even old damaged absober can go up although not leaking. For me its clearly product defect as the seal damaged resulting the leak. After spending a lot for all my 3 cars with them I'm feel cheated. This is not the 1st time as I encounter problem on parts like water pump, belt, seal, thermostat but this time around is too much. By sending the leak absober to Germany for testing will not cover my right as they can always say its my problem. I believe as a seller they should take full resposibility on the products they sell. What is my right here? What say you?
Re: Need Help & Advice
2 years product warranty for sure.
Check for finer details - I think I read life-time warranty for shock absorbers.
My friend had the same problem on that suspension but on a mini. Had to wait a while but they did reimburse the money. My friend was on B12 if i'm not wrong. Bought off eng soon.
Thanks for the feedback! As I'm from JB what should I do? Planning to file report to Consumer Tribunal. Any source of info?
Shem,
Yr fren encountered the prob wt Eng Soon too? How long did he waited?
