need advise on F20/F21 memory seats
firehorse
does the memory seat follow the key fob?
I realised mine does not, have to select position 1 or 2 manually
Thanks
Re: need advise on F20/F21 memory seats
Thanks
Logically it should follow........................
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
Each key fob should have its own memory 1 and 2...like the memory is based on the driver profile selected for that key fob...no?
My ex E60 yes, current F10 no.
ccb gahmen
ccb gahmen
In your driver's profile setting...you take key A open the door and set to one driver profile
Then change the profile to another for key B...done!
thanks for all the reply.... my previous e90 also no problem but the F21 when we change key....the memory seat doesn't change....will go back to WS to check
The function is always there but noticed that for some rides, it's disabled for some reason and needs to be activated.
Tks Slow_poke_driver, found some time to figure out the profile setting and the memory seat now follow the different key fob.
I am happy driver now. :)
12betlink4com
