My 325 is a little bouncy - this can be felt keenly on speeds above 80km/h. Can fellow bros advise me on what coilover/shocks or suspension i should change to reduce the bounce? I do not car much about lowering ride and am on stock 17inch run flats
If I am not mistaken, "bouncy" would mean that your suspension (more like you shocks) are either worn-out or your suspension set-up too hard. You may wish to check your shocks, if they are more than 3 years old or if you are on sports suspension. Aftermarket coilovers/springs&shocks may not be the best route as most of them are likely to be just as stiff if not more than the original sports suspension. If you are on the BMW sports suspension, you may wish to check in the classified forum to see if there are any original standard suspensions for sale.
