Need advice on shocks for 46 320 cab
BabyShots
Bro Shifus....
i just brought a set of ibach spring for my car e46 320 cab thinking of using it with my orignal shocks ..but i was just wondering will it be ok??
bros i am looking for a comfortable ride but i still wan to have a steady holding when comes to make turns ....
can anyone advise me on this ???please would like to here your thoughts on this...
if to change shocks what should i be changing to if i wanted what i have mention above....
Re: Need advice on shocks for 46 320 cab
Hi Babyshots,
you can try Koni or Bilstein B8 shock..........
ac323;459070 said:
Hi Babyshots,
thanks bro ..whats the difference btw them??
are you talking about koni fsd?
Hi babyshots,
yes Koni FSD.....both are good (different brand).........
you are looking at comfort and firm ride.......this combi best......if not coilover.......
ac323;459077 said:
Hi babyshots,
bro what combi will be the best for 1st comfort than little firmer ride??
btw where can i get the shocks at thye best price
Simple...
COMFY AND FIRM = IMPOSSIBLE.
Closest you can get to having a firm and stiff ride is as per what ac mentioned. Koni FSD struts + Eibach ProKit Springs.
I personally tried the above combi. It drops the car real well and its superbly comfortable.
But, its not stiff at all. It kills me during cornerings.
Right now, im on KW V2 coils. Probably one of the MORE comfortable coilovers that can give you a relatively STEAM amount of fast and furious.
So my advice, if you want a comfy ride. Forget bout coils. If you're a hardcore driver and the word "comfortable" is not in your dictionary, then coilovers is the way to go.
Recommended coilovers: Blistein PSS9/10 ; KW V2/V3 ; Cross JIC
My 2cents.
Herman;459354 said:
Simple...
My 2cents.
thanks for the advice bro...
bro do u know where i can get the koni fsd at a good price??
Hi babyshots,
you can call Jeff from Fong Kim :9108 8456 (Koni)
if not like what bro Herman said, go for the KW v2 (no regret) call Wilson at 9690 5511
MTL
happy hunting
was initially more or less prepared to go for H&R spring + strut bar just to lower the ride for the look. After reading this thread make me wonder should I go for the Koni FSD struts + Eibach ProKit Springs as suggested? Any advice on the comparison of these two where comfort is concerned. Cost wise is it a lot of different?
Your advice is very much appreciated. Tx
Hi wmb23,
there's a guy selling his Koni FSD shock plus spring (rssid), you may wanna do a search.....but of course budget allows go for the KW v2 coilover.....(this coil allows you to adjust to the height you want and still can have comfort ride)........
Coilover is definitley more costly than any sports suspension and sports lowering spring....
buy from Wilson (Wilman) he gives life time warranty for coilover....
