zennie
Hi guys,
Just to share with you my little mod. I bought myself a cyberspeed air filter and after half a day, I went back to the workshop to uninstall it. The low end suffered, while the mid and high end made little to no difference. I even connected the end to the piping by cutting a hole in the stock Mtech 2 brake duct, so that air from beside the foglight goes to the filter thru the hole at the front of the LHF fender.
I removed the cyberspeed and decided to mod my stock intake box. I dug a 3" hole at the front of the air box, just right beside the flat hole that draws in air from the side of the radiator. I connected this 3" hole to a pipe which eventually leads to the LHF brake ducts at the side of the foglights of the mtech 2 bumper.
Result? Better low, mid, high. There is very little restriction as almost double the amount of air can come in easily and best of all is that it is cool air. There is some effect of ram air as well. Of course this setup would mean that you'll benefit more from a panel replacement filter. The 3" hole is cut using a machine at the workshop which cut a perfect 3" hole, which can fit a rubber 90 degree pipe, then from there you can connect a regular flex pipe to bring in fresh cool air.
Sorry, no pics now....but just to share with you all on this. I don't believe in open pods for auto cars. Can't sacrifice low end.
