NightHawk;178166 said:I've done this mod on my ride. The M3 mirror was bought 2nd hand from a fellow forummer.
If your ride is not pre-wired for the autodim mirror, then you'll need to follow the steps in this post
http://www.bmw-sg.com/forums/interi...fitting-autodim-mirrors.html?highlight=mirror
Good luck.
cgoh;178168 said:Thanks. Is your a M3 mirror? From the picture, it does not look the same as the oval one I am getting. ....
NightHawk;178323 said:- Installation was around $100
Good luck.
NightHawk;178166 said:If your ride is not pre-wired for the autodim mirror, then you'll need to follow the steps in this post
roland1888;179648 said:Hi cgoh,
I was just wondering if the M3 rear view mirror you ordered is the oval one? If yes, may I know how you got it for?
NightHawk;179660 said:One point to note. The M3 mirror comes with a proprietory connector.
Most shops will NOT carry the corresponding male/female connector. Thus before you do the mod, do source for a mating connector from Eng Soon or Sim Lim Tower. Else you'll need to cut the connector & solder it directly.
To dismantle the mirror, just twist it (can't remember if its clockwise or anti clockwise). There will be a metal piece that is glued onto the glass that holds the mirror. Do check if the M3 mirror will fit into the same socket.
I believe it mentioned in my other post. To check if the autodim mirror works after you've installed it, cover the sensor at the front of the mirror (i.e. facing the front of the car. This is to simulate a dark environment) and shine a bright light into the back sensor to simulate bright headlights from the car behind. So bring your torchlight along.
Good luck
