Mockngbrd;387000 said:If that fails, and your engine is already started, you need to move your gear selector to the "D - D-s" area, and push it, up up down down left right left right, air-con on-off, on-off, re-start engine
i kid i kid
nYteMarE;387020 said:bigger wheels could help in this case..
or always carrying a full load of passengers...
and mock, i'm going to try your method next time..
oh wait. i have no idrive.![]()
Shadow;387035 said:Thanks Bros.
I thought of getting coilover but my frien's A4 got sound after that. quite scary.
Mockngbrd;387000 said:start up the car with the brake pedal full depressed, and your key in the half-position for 10 seconds. You should hear a chirp chirp sound, when that happens, start the car, press the brake pedal 3 times, throttle 4 times, then another 2 times on the brakes, the i-drive screen should show a "ride height adjustment menu", with this menu shown, you should be able to raise or lower your car's height as much as you want.
To change ride height with engine off, pull your handbrake lever up and down to pump the height away, like an air-jack.
i kid i kid
